Bang For The $$$
Old Apr 26, 2003 | 04:43 PM
txhotRS's Avatar
Bang For The $$$
Ok, what would be the best suspension mod for the money ??... BASICALLY, IF there were one thing (or a specific section) that was MORE IMPORTANT THAT ANOTHER, for suspension, what is it ??... I need to start upgrading suspension, however.. until next fall I only have so much money.. I'm eventually going to get a torque arm, subframe connectors, rear control arms, panhard bars, front and rear sway bars, 4-link ( i think that what they are called ), a performance bushing kit, probably eibach springs... etc... I have BONE STOCK suspension right now, but in a few weeks... I'm dropping a 325 HP small block, with a T-5, AND I'VE BEEN TOLD that I need to start upgrading... ANY SUGGESTIONS ??? THANKS SO SO MUCH, what will help the most WITH speed (traction, acceleration).. WHAT will help the most with ROAD-HUGGIN' and handling >??? you guys are a blessing:hail: :hail: :hail:
Old Apr 26, 2003 | 05:38 PM
82camaro's Avatar
Car: 82 camaro SC
Subframe connectors first. A 4 link would be a new rear suspension set-up(custom fabbing and quite a few dollars). Don't waste your money on rear control arms and a panhard bar if you plan to switch to a 4-link set-up--maybe are thinking of something else?
After the subframe Connectors, the order really doesn't matter that much--keep in mind that it all works together. If you drop it, you will probably want some LCA relocation brackets. You also might want to add a wonder bar and strut tower brace.
Old Apr 26, 2003 | 07:32 PM
txhotRS's Avatar
I'm not LOWERING my car... I'm dropping in a new motor... will I need a torque arm IF I HAVE MORE POWER ??.. what is a "wonder-bar" ?? what does it do... thanks guys
Old Apr 26, 2003 | 07:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
These cars should have come with subframe connectors from the factory. That goes without saying, if you haven't got those, you need them.
As far as modifications, by far the biggest bang for the $$$ things that I've ever done to my suspension were LCA lowering brackets for acceleration, and the "wonderbar" for handling and overall steering imrovement. Those 2 things together I think were less than $100.
The "wonderbar" goes across the front end of the car, and pushes up on everything, so your headlights look bigger.
Seriously, it connects the front ends of the "frame" portion of the unibody where the steering box and the idler arm mount, which greatly improves the steering. It's the rod that's between the sway bar and the power steering cooler, that's bolted under the sway bar bolts.
Old Apr 26, 2003 | 08:24 PM
txhotRS's Avatar
where can I get LOWER CONTROL ARM RELOCATORS... ??, i hear that it helps with wheel-hop
Old Apr 26, 2003 | 08:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Spohn... link at the top of the page
Old Apr 27, 2003 | 08:11 AM
ShadowZ28's Avatar
Car: 91 Camaro RS
Engine: L03 for now......
Transmission: 700R4 for now.......
definately spohn:hail: :hail: :hail: :hail:
Old Apr 27, 2003 | 12:28 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
FWIW - An often overlooked bang for the $$ suspension mod is to install poly sway bar bushings and end links front and rear. This really tightens up steering response. It was the first suspension mod that I did way back when, is a no-brainer install and doesn't cost much.
-Schultzy
Old Apr 27, 2003 | 12:36 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
TIRES! I have seen thousands of cars in my life that people have built (I happen to judge a major car show every year here in So. Calif) that people built the suspension to the hill but then just put crappy budget performance tires on it- they just try to find a tire that looks good.
Now take a car with a stock suspension and put some great rubber on it and very good roadrace shocks- and nothing else, and it will outperform most modified cars with sh*t tires.
In conclusion, don't try to save $200 bucks on your next tire purchase- you'll thank me later for the results you'll get.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Ghettobird52
Apr 21, 2020 08:44 PM
mustangman65_79
Apr 14, 2017 05:37 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Mr. Chevy
Sep 11, 2015 06:06 PM
