Alignment specs.. please help!
Old Apr 29, 2003 | 01:15 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Well I've finally got my suspension work done and now I need to get the alignment.. I've gone to 3 places already and everyones afraid to do work beacuse the car is lowered an inch! If someone could tell me what specs I need it would greatly help.. I had found some specs after searching the boards but when I went there they come out and starting telling me stuff about different tolerances and he doesnt know where to set them to.. Everytime I need something done be it the suspension work, simple exhaust fix or an alignment it always turns in to a project, must be the area i live in .. Anyways, its a 91 z28, I have the following suspension.
Moog ***** joints, inner/outer tie rod ends, upper strut mounts
Koni red adjustable struts and shocks
Eibach pro-kit
Some poly bushings
C5 wheels (17s front, 18s rear)
Now since it's lowered it obviously changes the camber/caster I guess so I don't know where to go for this alignment yet but I'm gonna keep looking for a performance place.. Any info is appreciated..
Old Apr 29, 2003 | 03:41 PM
82camaro's Avatar
Car: 82 camaro SC
Call around and find an alignment shop that will do a custom alignment--talk to the alignment tech. Call some good body shops too, they may have a suggestion or have the equipment themselves(and not advertise it). Specs I would use
camber -.5
caster left 4.5
caster right 5
toe + 1/16 inch
Some third-gens can't get those specs. If not, you want the camber to be as close to -.5 as possible, with both sides being the same. Caster, as much as possible with the left being .5 less than the right. Of course 1/16 positive toe.
Example, if the camber will only go negative to -.3 on the left and -.6 on the right, set it to -.3 on both sides. If the caster on the left will only reach 4, then set the right caster to 4.5. A good alignment tech should know all that though.
Old Apr 29, 2003 | 06:51 PM
SLAYER6669's Avatar
Those were the exact specs I brought to the guy I went to today after searching the boards for a while I noticed they were the most common specs mentioned.. Infact I think you were the one who posted them in one of the threads.. But when I went there he was giving me some crap about not knowing what the tolerance is or something I dont exactly know.. I'll have to find a better shop who knows what they're doing.
Old Apr 29, 2003 | 09:14 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
tolerances will be on the camber and caster +/-0.50
for toe =/- .010 not that it matters
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
