Spohn LCA and Relocation Brackets
Old Apr 30, 2003 | 10:09 AM
kdgreen's Avatar
Installed my Spohn Lower Control Arms and Welded in the Relocation Brackets this weekend. The wheel hop is completely gone. She will hook-up and roll now. The hardest part was getting the frozen bolts out of the factory LCA but I ended up just cutting them out. I cleaned up the factory Lower control arm brackets with a grinder then mig welded the new ones in. Will post some pics as soon as batteries on camera charge.
Old Apr 30, 2003 | 12:54 PM
MdFormula350's Avatar
awesome cant wait, because i want to know how easy the install was to do yourself, my grandfather has a mig welder i believe and we might try it ourselves.
Old Apr 30, 2003 | 01:40 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
kdgreen,
Congrats! It is nice when a product performs as advertised, eh?
MD,
It is a very simple install. I have posted pics several times of mine and I don't want to completely hijack kd's thread. It took about an hour to do both but if I had to do it again I bet it could be accomplished in less than 1/2 hour.
I think you and Grandpa should go for it!
-Schultzy
Old Apr 30, 2003 | 03:06 PM
CaysE's Avatar
did you get adjustable or solid LCAs? what's the advantage of adjustables, anyway?
Old Apr 30, 2003 | 10:59 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
Adjustables let you recenter the rear fore/aft when the shop that installed your brackets screws it up and throws your geometry off
Old May 2, 2003 | 02:21 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I put relocation brackets on, and used my stock LCA's... and boxed them. Cheaper than aftermarket... and my rear is still fine. There is a bit of play in the relocation brackets after you put the first bolt in. Just make the back flush and parallel with the back of the original LCA bracket... and you'll be lined up. Worked for me.
6speedIROC
16
Mar 15, 2023 08:33 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 26, 2015 03:37 PM
luvofjah
Sep 10, 2015 10:41 AM
