No rear sway bar or panrod arm
Old May 3, 2003 | 10:37 PM
1982Camaro383's Avatar
Question for you guys I have a 1982 Camaro which does not have a rear sway bar or panrod arm would it be beneficial to install one and how hard is it to install them. Any help would be greatly appreciated.
Thanks,
Justin
1982 Camaro
Old May 3, 2003 | 11:19 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
if you dont have a panard rod (they come stock) your car would not be vary safe to drive ! the rear will stear to car with nothing to locate it
mike
Old May 3, 2003 | 11:24 PM
i believe it has panrod but it does not have rear sway bar
Old May 4, 2003 | 07:40 AM
Bjase's Avatar
Car: 88 IROC
The panhard rod goes from the rearend on one side to the body above it on the other. Unless there's an aftermarket suspension in there, you'd probably not be able to drive the car without the back tires rubbing their inside &/or outside edges as the car moves sideways over the rear.
I suggest going to a junkyard and grabbing a sway bar. Pretty much all the 3rd gens have them, and it will be way chearper than a new one.
Old May 4, 2003 | 10:00 AM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
yeah it makes a world of differnce to add a working panhard rod. mine broke and neva knew until somebody who knows camaros told me. then i fixed oit and can put power to the ground coming out of a corner w/o goin sideways
Old May 4, 2003 | 12:51 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Well...this may sound dumb, but it took me a while to figure out what a "panhard rod" was because all the repair manuals refer to this part as the "track bar".
I am assuming you know where the sway bar connects and what it looks like and have verified that its not there. Who knows? I'd get one though. $15 at your local yard. Bring a hack saw w/ a sawzall blade b/c the bolts on your donor car will probably be impossible to torque off.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
