Bling? Too Much? Where the rubber meets the road
Old May 5, 2003 | 07:31 PM
NuclearPwrIroc's Avatar
I just did that title to get your attention.
Down to business. im looking at 18x8.5's (which are sized to fit) and looking at a 275/35/18 on the rear and a 245/40/18 on the front? out side of possible oversteer and a crappy ride any other laws of physics that im going to be breaking unknowingly??
Also, correct me if im wrong but if a 275/40/17 (25.66 diameter) fits without rubbing on the car, then a 275/30/18 (25.7 diameter) SHOULD clear if i have no rubbing, at full lock rubbing is alright to me, being if im at full lock at speed im about to die anyways. So anyone with 18's help me out
Old May 5, 2003 | 11:23 PM
CrazyHawaiian's Avatar
Car: too many ...
You are correct about the 275's in the front. With actual sizes (wheel and tire) matched up you will have the same results. Should work providing the fronts have the correct offset/backspacing. Another thing to keep is mind is your stance. What kind of drop do you have? One thing I'm not sure of is tire sizes for those wheel sizes. Not sure if a 275/35/18 will fit on a 18x8.5. When you run less sidewall, the fitments become less forgiving as far as width. Check the tire manufacturers and if they say it'll fit then go for it.
Old May 7, 2003 | 11:08 AM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i wanna know the same thing, if i can ut on 265/40wr-18 on a 8.5" wide rims. i'm looking at 18"x8.5" rims for ,my car. after i finish the install on my exhaust
Old May 7, 2003 | 02:46 PM
Kandied91z's Avatar
a 275/35 fits perfect on a 9.5 i wouldn't try to put them on any other size rim.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
gta_knight
Sep 23, 2015 04:59 PM
roysatikas
Sep 22, 2015 08:15 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
BlackFormula
South East Region
Sep 8, 2015 09:59 AM
