aluminum drum proportioning valve
Old May 7, 2003 | 11:56 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I was told that when I switch to disk brakes from my rear drums that I will NOT have to change my proportioning valve on my 1986 Iroc because that it originally came with aluminum drums. Is this correct?
Chris
Old May 7, 2003 | 12:32 PM
ede's Avatar
ede
no, if you have an aluminum PV, flat sided machined looking you don't need to switch, if you have a roundish cast looking PV you do
Old May 7, 2003 | 01:11 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
It makes no diffenence if you have Aluminum or Iron Drum brakes
now, you will have to change the Proportioning valve for Disc Brakes,
Old May 7, 2003 | 02:01 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
So ede says I do not have to switch and DJP87Z28 says I will?
By the way, I do have the flat sided machined one.
Chris
Old May 7, 2003 | 02:09 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
change it
either take the prop valve from the donor car or get a pair of adjustable ones from jegs i did the conversion without the prop valve and its been hell ever since so far ive had to change the rear calipers at least 3 times im gonna go with the adjustable ones
Old May 7, 2003 | 02:25 PM
DJP87Z28's Avatar
Chris
Were you trying to say " I have aluminum drum brakes now"??
And do you need to change the present prop valve used with the Alum Drums???
Old May 7, 2003 | 02:34 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Correct. I have the aluminum drums on my car right now with the square machined proportioning valve. I was wondering if I need to change the proportioning valve when I switch to rear disks.
Chris
Old May 7, 2003 | 04:20 PM
DJP87Z28's Avatar
All right, at least that clears up that point. Yes I would change the Proportioning valve. Get the one from the donor car if possible, or buy a new one for a Disc brake application.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
