I dont think my wheels fit
Old May 8, 2003 | 10:27 AM
XChris1632X's Avatar
Car: 83 Z-28
Engine: LG4 305
i just got some 15x10 ttIIs and they have a 3 inch backspacing in the back. it seems like the studs may be too short. but someone here told me they would fit. the bolt screws on about half way. am i ok.
Old May 11, 2003 | 09:04 PM
Car: 83 Z-28
Engine: LG4 305
no one?
Old May 11, 2003 | 09:10 PM
25THRSS's Avatar
If they only go on half way then no you are not ok. You might need longer studs.
Old May 12, 2003 | 11:57 PM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
Don't risk this one. I did once and I lost a wheel which took the door and fender with it. Now I always run open ended lug nuts so I can make sure the studs are long enough. Spend the extra few bucks on longer studs....it is worth it,
Tyler
Old May 13, 2003 | 12:26 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Tyler
Yep! I fully agree.
Old May 13, 2003 | 03:07 PM
(BR)G-Machine's Avatar
Check with the wheel manufacturer to see what open ended lug nuts they recomend for those wheels. Wheels can be picky about the lug nuts used on them because the angle of the cone it is secured by has to match the wheel.
Old May 17, 2003 | 12:19 AM
Car: 83 Z-28
Engine: LG4 305
i think i am definatly going to get longer studs but with torq thrust IIs do you have to have washers and shanks. just trying to find out before i mount them. i am mounting them myself so i cant just go and ask someone.
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
milk
Aug 10, 2015 06:26 PM
