Tried to bleed front brakes today and...
Old May 10, 2003 | 05:31 PM
84 Challenge's Avatar
nothing! Pressure does not build up when pumping brakes with ignition off. I only need to do the front calipers. What's the proper procedure for bleeding? Thought I was doing it right, but guess not.
Thanks,
Brandon
Old May 10, 2003 | 06:10 PM
llvll4l2c91350's Avatar
i would let it gravity bleed first. and check to make sure the bleeder screws aren't clogged.
Old May 10, 2003 | 06:13 PM
I didn't do it right, I think. Didn't wait for the fluid to stop spewing out of the bleeder valve before closing.
Brandon
Old May 10, 2003 | 06:24 PM
BTS88IROC's Avatar
Are you just opening the bleeder valve and then pumping them? If you do it that way you are just going to get air back into the system.
Old May 10, 2003 | 07:48 PM
The wife pumped, then she depressed the pedal. After that, I opened the vavle.
Old May 10, 2003 | 11:44 PM
BTS88IROC's Avatar
Ok, well you are going to hear lots of different things from different people on how to bleed brakes. The way I've always done is it to open the valve, depress the pedal, shut the valve, and release the pedal, keep doing that until they are bled. Its a little bit slower that way but its always worked for me. Also make sure you start with the one farthest away from the master cylinder.
Old May 10, 2003 | 11:54 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Are you filling the fluid reservoir and replacing the cover before bleeding process?
Old May 11, 2003 | 12:00 AM
Yes!
Old May 11, 2003 | 09:29 PM
25THRSS's Avatar
Why do you need to start with the one furthest away from the master cylinder?
Old May 16, 2003 | 12:57 AM
25THRSS's Avatar
anyone?
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
