Sway bar links
Old May 14, 2003 | 06:50 PM
guza's Avatar
Car: 1985 Berlinetta
Engine: 305 4BBL
Sway bar links
I put on a new set of Energy Suspension Poly sway bar end links. How far am I suppose to tighten them down. The directions were gone before I read them.
Old May 14, 2003 | 11:14 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
Tighten them until you can move the washers but they wont spin around. That's the reccomended way to do it but you can adjust it either more loose or more tight depending on the suspension feel you want. I run mine really tight and it really helps around the corners, dips, bumps.
Old May 15, 2003 | 10:50 AM
CaysE's Avatar
Make sure you're doing this with the wheels on the ground, otherwise, when you lower the car, they'll be loose again. Not that it's a big deal or anything, you just have to do the job twice instead of once.
Old May 15, 2003 | 11:00 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i tighten mine until the bushing start to "compress" if you watch it, you will see what i mean.
Old May 15, 2003 | 08:41 PM
Spdfrk1990's Avatar
i tighten mine till the bushing equals the size of the washer.
Old May 15, 2003 | 09:39 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Just like above: I tighten them down until the edges of the bushings are flush with the sides of the washers.
Ed
Old May 15, 2003 | 09:50 PM
MdFormula350's Avatar
this measurement in the pic is not 2 5/8 right? i want to order some es poly rear links, so where do i find the 2 1/4 ones.
at least jegs didnt seem to have those size neither did summit.
that is a pic of my stock rear sleeve from the end link.
i am looking for es poly ones or prothane endlink kits, the es kits look nice being zinc coated, just need to find the right size.
also have no need for sway bar bushings, i already bought those. thats why i want to find where i can just get the endlinks.
Old May 15, 2003 | 11:45 PM
ebmiller88's Avatar
If you want "stock" length sleeves, you'll have to reuse the old sleeves. I haven't found any aftermarket sleeves that are the same length. My ES links were a bit longer.
Ed
Old May 16, 2003 | 12:01 AM
ronterry's Avatar
Car: '94 Corvette
Dog gone it, 'Spdfrk1990' I thought you where talking about tighting it till the bushing equaled the thickness of the washer, not the diameter.
Ron
Old May 16, 2003 | 12:46 AM
thanks ed, i will get the 2 5/8 ones then.
Old May 16, 2003 | 01:09 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
2and 5/8 to 2and1/4 enter vise and hacksaw. should take about 5 min
Old May 16, 2003 | 01:14 AM
good enought for me ordering now, thanks..
i guess the aftermarket endlink sleeves seems to be a bit longer.
Old May 16, 2003 | 04:15 AM
Spdfrk1990's Avatar
nah i was talkin about what eb miller said u would have to get it pretty freakin tight to get it that thin.
Old May 16, 2003 | 06:39 AM
Dewey316's Avatar
Car: 1990 Camaro RS
lol, it woudl take some serous force to get them the same thickness as the washer i bet you would break something first.
Old May 16, 2003 | 03:59 PM
Matt_91RSTPI's Avatar
There is a torque spec for these in the Helms manual. I don't have it handy so maybe someone else can look it up. I think it's around 16 ft lb.
Old May 16, 2003 | 04:11 PM
Spdfrk1990's Avatar
i did mine to 15ft lbs thats what it said in the book.
Old May 16, 2003 | 07:51 PM
demonchild's Avatar
its nice that you actually own a torque wrench
Old May 17, 2003 | 02:08 AM
CaysE's Avatar
Don't we all own a $350 Snap-On torque wrench with digital read out and vibrate/beep alert???
Oh wait, I was dreaming.
Old May 17, 2003 | 06:05 AM
ronterry's Avatar
Car: '94 Corvette
hmmm -- Where's my sleeping pills, cause I want one !!!
Ron
Old May 17, 2003 | 09:01 AM
demonchild's Avatar
hey i wonder if we could get a internet deal if we get enough people to buy one. carftsmen and snap on make basic ones for like 50 dollars...
Fanatic1074
Oct 3, 2022 05:57 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
