brakes are pulling
Old May 14, 2003 | 10:09 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
brakes are pulling
on my camaro the front brakes are pulling real hard to the left. i have installed new pads, rotors, and calipers, could this be a proportioning valve? or something else? all help is appreciated
Old May 14, 2003 | 11:27 PM
BTS88IROC's Avatar
Replace your front brake lines, this is most likely the cause. My current Iroc had this problem when I bought it and that cured the problem.
Old May 15, 2003 | 12:16 AM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
plus don't forget to bleed the whole brake system when you are done changing the lines. Problem should be solved.
Old May 15, 2003 | 07:08 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
This would be a good time for upgrade to Stainless Steel Braided lines.
Old May 15, 2003 | 09:40 PM
camaro03's Avatar
Car: 1982 camaro
thanks guys for your fast help
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Aug 21, 2015 01:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
