Wheel backspacing questions
Old May 19, 2003 | 03:19 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Transmission: broken
I have found a set of wheels that I really like and was wondering about the backspacing I would need. I want to run 17x9.5 in the front and 17x11 in the back. Also, would it be better to run a 17x8 in the front? I know I will probably have to "massage" the inner fenderwell and roll the lip, but I want the wheel and tire to be flush with the fender. I absolutely hate how a wheel looks sticking out.
Thank you in advance for your help!!!!
Old May 19, 2003 | 10:18 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
using 5.5" backspacing on the 17x9.5 wheels you will need to grind a little off the tie rod to clearance the wheel. you can also use 5.5" on the rear with the 11" ones. better if you can get the 11" wheels wit h6" backspacing.
Old May 20, 2003 | 12:14 AM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
So it would be better to run a 17x8 up front?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
