Drum->Disk, problems, need help
Old May 19, 2003 | 07:50 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Well, I am putting a 9-bolt from an 86 bird into my 92 RS which had a 10bolt drum.
Well I got new calipers and I am trying to bleed the brakes, I got these speed bleeders so I can do it alone. But when I depress the brake pedal(engine off). Nothing comes out, I even took the bleeder all the way out and no fluid is coming out. Resovoir is full so I dont know what the problem is, I have tried both sides.
For the second problem, the old ebrake cable was too long, so I got new cables and these are even longer!!! I got the ones for an 86 so I dont know what to do now.
Any help wpuld be great.
Chris
Old May 19, 2003 | 10:52 PM
Car: 92' RS
Engine: LO3
Well I solved the bleeding of the brakes problem.
Still have the ebrake cable problem.
Old May 20, 2003 | 05:40 PM
(BR)G-Machine's Avatar
Did you order an 86 ebrake cable or a 92? Just curious... because you could run the pn to see if the 10 bolt had a different cable than the 9. Or you could take the ebrake assembly from the parts car yu got the 9 bolt from.
Old May 20, 2003 | 08:33 PM
Car: 92' RS
Engine: LO3
I ordered it for an 86 car. And getting it from the car it came from is not an option. I am just going to modify my old one to make it work.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
andy74
Sep 3, 2015 08:41 AM
