What size are they?
Old May 25, 2003 | 06:06 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
What size are they?
Im trying to find out what size Sway bars I have. I got the code FE2 but that code is for a bunch of sizes....I measured the front and rear and they roughly measure about, <front measures about 1" 3/8 and the rear measures about 1" >
What is that converted to MM? I want to replace them with the greasable ES bushing they have at AutoZone...so I need to know exactly what size I have,,,
thanks
Old May 25, 2003 | 06:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Screw the codes.
Take a Crescent wrench, and tighten it around the bar where the bushings go; slip it off, and measure it with a ruler.
Reality is ..... reality. Codes are prone to being wrong, from stuff being changed during the life of a car.
Old May 25, 2003 | 08:06 PM
I forgot to give the measurement I got with a tape measure..
The rear is 7/8th and the front is I think 1"1/4 or 3/8's
so what would that be in MM?
Old May 25, 2003 | 10:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
1" = 25/4 mm
Take what you got and do the math, and go to the store and buy your parts
I do not want to be held responsible for the results. This warranty gives you specific legal rights which may vary from state to state; warranty may not be valid in all 50 states; batteries not included; etc. (Translation: you measure it, after that you're on your own, you better get closer than 1/8")
Old May 25, 2003 | 10:43 PM
the measurement I got is from doing it with a cresent wrench like you said to do...the rear is 7/8
My cresent wrench wouldnt go out far enough for the front but Im pretty sure its 1" 1/4
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
