Bad power brake booster ??
Car: 92 Camaro RS
Pedal seems to travel furthur than normal and no amoint of effort will lock the brakes. The front rotors are smoothe and about half of pad thickness is left. Rear shoes and wheel cylinders are new. Rear drums were turned. Could this be a bad booster and is there any way to test? Thanks
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
a bad boster can make it hard to press the pedal. bad master cylinder is what it sounds like. also, make sure the rear drums are adjusted properly. will contribute to a low pedal.
