Welder needing help.
Old May 27, 2003 | 09:54 PM
Rage13's Avatar
Car: 89 Firebird
I'm ready to start work on a roll cage for my car, made of cromaly steel. I've heard you can only TIG weld this stuff, is this true? Also all the welding I've done is TIGing 316L stainless steel, how is the cromaly different? Just looking for any tips before I try welding some scrap pipe.
Old May 28, 2003 | 08:19 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I don't know if you can ONLY TIG it, but I would. Much cleaner weld, both in appearance and quality. TIG welding steel is just like TIG'n stainless but it doesn't "flow" as quick. I'd practice a bit and then hop right on it, just like riding a bike.
Ed
Old May 28, 2003 | 08:23 AM
ede's Avatar
ede
i beleive you can also use GMAW on CM, i ithnk all the winston cup cars are welded that way. i'd stick with GTAW since you're use to it. basically it's the same, i believe you'd want to watch for hot cracking and imbrittlement in the HAZ.
Old May 28, 2003 | 06:09 PM
Rage13's Avatar
Car: 89 Firebird
alright, sounds good so far.
hey ede, what would the hot cracking and imbrittlement look like? and what dose HAZ stand for? i've never looked at any welding books or classes(so i don't know alot of the terms), just learning by doing pretty much.
Old May 29, 2003 | 05:24 AM
ede's Avatar
ede
a crack, you can't see imbrittlement, heat affected zone
Old May 29, 2003 | 02:53 PM
Rage13's Avatar
Car: 89 Firebird
Cool, thanks ede
IROCZ1989
Jan 24, 2016 03:55 PM
beachrodder
Aug 25, 2015 08:05 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
