Lazy steering
Old May 30, 2003 | 07:41 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Lazy steering
My '87 IROC has really lazy steering. It will seem like it'll just go where it wants, when it wants. You almost have to fight to keep it going straight sometimes.
It feels like the wheel and the steering wheel just "lose" connection for a second. I know I'm probably describing this poorly, but hopefully someone gets the idea.
Any idea? I just put new tires on as well...
Old May 30, 2003 | 12:05 PM
87LTcamaro's Avatar
steering arm
my 87 camaro did this too. i replaced the steering arm and the idler arm and it fixed it. also did you get an alignment w/ your new tires? if not that would be why it goes where it wants. basically if i were you i would check your front end. tie rods and all of that stuff. good luck.
Old May 31, 2003 | 12:48 AM
Spdfrk1990's Avatar
The steering arm that just a peice of metal that connects to the steering box and the center link how did that help?? unless maybe the holes wore out dunno.Do u mean u replaced the steering box?
Old May 31, 2003 | 12:17 PM
87LTcamaro's Avatar
hm
well, i thought it was called the steering arm, but anyway the piece im talking about goes between the two wheels and makes them turn. maybe you call it something different.
Old May 31, 2003 | 04:05 PM
Spdfrk1990's Avatar
i think u mean the center link
Old May 31, 2003 | 04:10 PM
87LTcamaro's Avatar
ok, well, you are probably right. but what is the steering arm then? is it the bar that connects from the center link to the steering box?
Hung Start67's Avatar
I think he means pitman arm..but change that idler arm and get a front end alignment.
Old May 31, 2003 | 04:13 PM
Spdfrk1990's Avatar
yes the steering arm is called the pitman arm and it does go fron the center link to the steering box
Old May 31, 2003 | 04:18 PM
87LTcamaro's Avatar
sorry about that guys.........so i replaced my centerlink and my steering arm and it fixed my lazy steering. i hope this helps.
(thanks for the help w/ the terminology fellas)
Old May 31, 2003 | 04:22 PM
Spdfrk1990's Avatar
i would just buy the whole front end kit from spohn or somethin if i was him
Old May 31, 2003 | 04:37 PM
82camaro's Avatar
Car: 82 camaro SC
Pitman arm is a no-wear item--it can't wear out, it has no joints. Centerlink and Idler arm are a couple of good places to start looking. Could also be some wear in the steering box or the rag joint. Basicly, have the front suspension checked out, and replace everything that is worn. I would skip buying a 'kit' unless most of the parts are worn. A good alignment can do wonders for steering 'feel'.
Old May 31, 2003 | 04:44 PM
Spdfrk1990's Avatar
i bought a kit for my car cause i bet some of the parts were original and my steering feels real tight now along with the wonderbar.
Old May 31, 2003 | 04:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Also check the "rag joint" where the steering column hooks up to the steering gearbox.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
