LCAs are a pain in the...
Old Jun 1, 2003 | 04:36 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I got the nuts off but I can't seem to get the bolts out of their holes. I'm trying to replace my stock rear LCAs, yet I can't seem to get them out of the little rubber bushing part. I've hit it with a hammer as hard as I could with no luck. They've been lubed with WD-40 so I don't know what to do now.
Old Jun 1, 2003 | 05:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Cut them and replace them.
Old Jun 1, 2003 | 05:23 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
get a torch and heat the hell out of them then beat on them with a heavy hammer
Old Jun 1, 2003 | 05:40 PM
MdFormula350's Avatar
i loaded the old ones with wd40, pb blaster and anything else that penetrates. and a couple wacks with a hammer got mine out.
Old Jun 1, 2003 | 05:55 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
cut them... where? and with what?
Old Jun 1, 2003 | 06:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
With a hacksaw or a torch. Anywhere that goes through the bolt. I'd suggest cutting the head and the end of the bolt off. If it's a stock LCA it's garbage anyway; if you are using a torch, you can cut it up into as small of pieces as you need to get it out of there.
Old Jun 1, 2003 | 07:27 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Are you able to turn the bolt with the wrench?
Old Jun 1, 2003 | 08:25 PM
Spdfrk1990's Avatar
I got mine out with a air hammer trust me if u have acess to one it will work.I had my dad turn one side with the wrench to try to break it loose while i used the air hammer.
Old Jun 1, 2003 | 09:23 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
I just smashed the crap out of mine with a large hammer until they backed out.
Old Jun 1, 2003 | 10:02 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I can turn them about 1/4 turn but they're stuck from the rubber
Old Jun 1, 2003 | 10:04 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I was hitting mine with a hammer for literally 5 minutes straight as hard as I could... Didn't do anything but chew up the bolt.
Old Jun 1, 2003 | 10:06 PM
Spdfrk1990's Avatar
same here but the air hammer did the trick keep the nut on the bolt a lil tho so u dont tear the bolt up
Old Jun 1, 2003 | 10:17 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Go to the hardware store and buy Liqud Wrench. Keep spraying it on to help the rust go away. If you have a dremel or anything to drill or cut it out, use that.
Old Jun 1, 2003 | 10:21 PM
Spdfrk1990's Avatar
my rust was on the inside the bolt was rusted to the metal inside the bushing so nothing could get in there
Old Jun 1, 2003 | 10:27 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Well, liquid might be able to seep in there and help. Do you have anything to cut the bolt with or drill it out?
Old Jun 1, 2003 | 10:30 PM
Spdfrk1990's Avatar
i was gonna use the recipicating saw if the air hammer didnt work and just cut the bolt off between the bushing and the body
Old Jun 1, 2003 | 11:40 PM
BORLAZ06's Avatar
its only a bolt...ur weak
Old Jun 1, 2003 | 11:42 PM
Spdfrk1990's Avatar
weak lol ok just cause urs came out easy i bet nething u couldnt have got mine out. wait u live in CA things dont rust as bad there so u wouldnt know. i have to do alot to make my car rust proof in ohio plus i dont even drive it in the snow
Old Jun 1, 2003 | 11:48 PM
BORLAZ06's Avatar
mine were rusted as hell...i was so strong i broke them off.
Old Jun 1, 2003 | 11:49 PM
Spdfrk1990's Avatar
hehe well i alrdy got the nuts off mine the only way to brake them maybe was with the hammer if i was to strong it shattered the bolt
Old Jun 1, 2003 | 11:53 PM
BORLAZ06's Avatar
lol
Old Jun 2, 2003 | 05:12 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I've already bought a ton of new tools since I got my new job a month ago...
power drill and bits, 4.5" angle grinder, a set of 8-19mm wrenches AND sockets, a 24" breaker bar, and some other junk.
YET I NEED A SAWZALL NOW, RIGHT?
Old Jun 2, 2003 | 06:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you have an angle grinder, then use that. Put a cutoff wheel on it and cut something (besides the car body itself).
Stock LCAs aren't worth saving. Just destroy it until you can get the pieces out.
Old Jun 3, 2003 | 10:33 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
I have a better idea how bout calling up a friend and buying a case of beer. just pull out the lawn chairs and sit and drink...and drink....and drink and see how many funny ways you can think of to get that stupid bolt out. than after the hang over the next day try one of them.
Old Jun 3, 2003 | 10:47 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I would have to disagree with the above suggestion. I could see you forgetting your ideas.
Old Jun 3, 2003 | 11:15 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
if u hav the car already on jack stands take the jack put it under the lca and jack up a bit and put enuff pressure on the lca to get it to move up a bit and then hit the bolt with the hammer, if that doesnt work just get a big center punch and put it in the centerof the bolt and pound away.
Old Jun 5, 2003 | 12:23 AM
Coxy's Avatar
Car: 91 RS B4C
Engine: 355
Transmission: TH 350
Air hammer, its the best tool for an air compressor, it should come with it.
Old Jun 5, 2003 | 04:24 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
Jorlain
Oct 8, 2015 01:57 AM
