Original shocks
Old Jun 5, 2003 | 10:48 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
Original shocks
My shocks are pretty rusted on the lower mount. I have been spraying them all day with supertech rust breaker from walmart and the bolt wont budge. Does anybody have any suggestions? Could it be because i didnt do the top mount first. I have worked on the is for like 6 hours total.
Old Jun 5, 2003 | 11:30 PM
MdFormula350's Avatar
maybe try tapping it alittle with a hammer and maybe try and use a big long breaker bar. thats what i probably need to do when i change my shocks because mine look pretty rusted also.
Old Jun 6, 2003 | 04:00 AM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
Torch it!
Old Jun 6, 2003 | 08:41 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Break the shock mounts off and get the $5 replacements in the help section at Auto Zone. They work fine and come with new bushings so you have an extra set.
HTH...
Ed
Old Jun 6, 2003 | 02:36 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
from what i saw when i was working on they were welded on to the rear end. I may be wrong though
Old Jun 6, 2003 | 04:44 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hmm
maybe u could try using an impact air rench
Old Jun 6, 2003 | 08:23 PM
ebmiller88's Avatar
Nope, not welded. Use a 21mm socket to remove them.
Ed
Old Jun 6, 2003 | 10:34 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Well I didnt have to replace lower mount. I just torched them and used a 3' breaker bar or them. Thanx for all the help
-Chad
Hotrodboba400
Dec 10, 2019 07:07 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
