Line lock outputs - should I use one or both?
Car: 1986 IROC-Z
My Hurst line lock has two outputs, so it seems logical to run one output to one front brake line and the other output to the other front brake line. Nowhere in the directions does it show this -- it always shows only one output used with a tee, and the other output is plugged. Why do they have two outputs if only one is used? Can I eliminate the tee and use both outputs?
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have the Hurst line lock also and I used both ports, one for each front brake. 3 years so far and no problems.
Hope that helps
Hope that helps
