Car shaking help!very annoying :P
Old Jun 14, 2003 | 02:39 AM
myz28u's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
The car shakes when I drive. Usually it has a shake all the time and the steering wheel shakes in my hands. I have a basically whole new front end....center link, idler arm, struts, inner and outer tie rods....rear shocks and stabalizers also brand new. Front has been aligned and wheels balanced twice. I know my trans mount is bad and Im replacing it tommorow, don't think it would cause this though.....
couple more things...Ive noticed the shake seems to be coming from the rear. It only started after the shop redid all my brake pads and shoes Im pretty sure...car also pulls to the right slightly and steering wheen stays slightly off center toward the right....any ideas?
Old Jun 14, 2003 | 10:46 AM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
could be the driveshaft....try getting an aluminum one, i've heard many people have gotten rid of the vibrations after installing the aluminum one over the steel one
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
Wish I could help, but I am puzzeled, could be a number of things from bad rim or something of that sort. Need more time for good guys to reply. Andy
Old Jun 14, 2003 | 11:25 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably a bad tire, or maybe more than one. Most of the time tires are the cause of all of the problems you describe.
As far as the pull, swap the 2 front tires, see if it pulls to the other side; if it does, you have your answer.
Other common possible causes include a bent wheel or bent axle.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
