Door flex after SFC help
Old Jun 14, 2003 | 09:08 AM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
hey ya'll. Been so consumed with brake stuff lately I forgot about others things I needed to work on.
I had MAC sub frames welded in about 6 months ago. Great feeling. But, I am trying to address the door flex issue that did not really go away after installing the SFC's.
As you know, the MAC's weld in at the 4 subframe points (basically 2 parallel bars running from front to back with about 1-2 feet between them).
I'm trying to figure what else I can weld on to make the doors tighter w/o having to buy perimeter SFC's.
I guess I could either
a) run tubular bars along the door sills,
b) run tubular bars from the front weld points of the MAC's to the front-most portion of the area under the door sills,
c) fab up a bar that welds between the MAC's at right angles (basically making an 'H' pattern).
Since this is a convertible, I do have stock square tube SFC's that run the length of the doors (but evidently are crap anyway). Maybe I could modify these somehow.
Can anyone help out with this engineering problem?
Old Jun 14, 2003 | 09:49 AM
CrazyHawaiian's Avatar
Car: too many ...
Have you replaced the door pins/bushings? A rollbar would also help stiffen the chassis.
Old Jun 15, 2003 | 12:06 PM
WHats up CrazyHawaiian??
Umm...I had thought about door pins/bushings but I did not think it was an issue since my doors never creak/squeak when I open them and they close nice and solid. Its most obvious when taking corners on roads with uneven surfaces (and I'm just talking about mild cornering).
And yes I have given lots of thought to the roll bar stuff. I think I'm going to start w/ a 4-point and see how that goes.
Its a little further down my list of things that have to be done. Gotta get a new top this weekend and then going to put in my new 350 in a couple of weeks. Then I'll see how much $$ is left and then I'll try to get started on the cage.
Take it easy
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
