Difference of PSI in pressure/return hoses with power steering pumps...
Old Jun 17, 2003 | 02:15 AM
89ProchargedROC's Avatar
I am using a GM type II pump with my motor this time around and i know i need a 2500psi rated pressure rated line to the actual pump, but the return line isn't under a lot of pressure as i've learned and doesn't need the expensive teflon lined hose.
but
how much pressure is there in the return line? i need to make sure so i know what hose to buy
thanks
Old Jun 17, 2003 | 05:27 AM
ede's Avatar
ede
return is very low, most use worm drive hose clamps to seal. i'd guess in the 25 psi range, but really don't know the exact number
Old Jun 17, 2003 | 12:35 PM
thanks...either way i'm not going to go through the trouble of returning my -10 teflon hose for normal braided. I'd only be saving like $6 and shipping would be that much
oh well
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Mar 22, 2019 09:39 PM
colton_carlson
Mar 8, 2019 12:21 PM
fasteddi
Sep 2, 2015 10:29 AM
