stock prop. val.
Old Jun 21, 2003 | 10:54 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
stock prop. val.
Hello all,
Does anyone know how to disable the stock prop val on the master cylinder? I have a 1989 Firebird, I installed the baer rear disc brakes. I just to make sure I disable it or remove it. I must use the baer prop valve. I must disabled the stock prop. val. or remove the factory prop. val. Any suggestions or comments will be greatly appreciated.
Brad
San Diego
Old Jun 23, 2003 | 02:04 PM
'82 Beater's Avatar
The stock prop. valve is right under the master cylinder, attached with hard lines. It should come off with a flare wrench. You'll probably have to bend and flare new lines to attach the new Baer prop valve.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
