problems with new rear brake calipers...please help...
Old Jun 25, 2003 | 01:49 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
ok i got a set of rear brake calipers from autozone and the problem is that they will not take any fluid.....i tried bleeding the brakes but nothing would come out..........i didnt hook up the parking brake......would this affect it??
Old Jun 25, 2003 | 02:31 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Maybe the flex hose is plugged.
Old Jun 25, 2003 | 02:37 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
are you talkin bout the hose that runs up to the caliper......cuz i dont believe that is plugged cuz when i took off the line to the caliper there was fluid coming from not only the line but the caliper too.............
Old Jun 25, 2003 | 02:40 AM
Yep, thats the hose. There is also one from the frame to the axle.
I had a crossthreaded bleeder valve on a rebuilt caliper from Autozone once (but it just always leaked). Will it bleed if the valve is removed from the caliper?
Old Jun 26, 2003 | 12:40 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah the lines are fine they bleed....actually i talked to the guys at autozone and one of them told me to do somethign with them that may work cuz he had to do it on his 78 trans am with rear disc's......if it doesnt work then i guess i'll just go to midas or something....
Old Jun 26, 2003 | 12:41 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
matt
open the bleeder valve and then pump the brake pedal till fluid starts coming out, the close the bleeder valve and bleed them normally
Old Jun 26, 2003 | 12:46 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
i tired that.......after about 20 pumps we decided that there was something wrong....
Old Jun 26, 2003 | 12:56 AM
Jproz1167's Avatar
matt
how much did your calipers cost, I have a sticking one and don't want to faint in front of the guys at autozone when they tell me
have you tried pumping with the brake lines diconected & doing one at a time, had this problem when I did the rear brakes on my 82 vette, couldn't get fluid out of the bleeders, then after tinkering with each bleed on the calipers they finally started squirting, I think you have a bad air pocket, much like my vette did
Old Jun 26, 2003 | 01:59 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
umm im sorry but i couldnt really understand what you meant there.....i'll just state what i have done and you can tell me what else i should do
i tried bleeding them while hooked up...nothing
disconnected the line from the caliper and fluid came out of both the caliper and the line
tried messing with the stud in back where parking brake would be.....nothing
what the autozone guy suggested was to keep the counterweight off of the old parking brake assembly and put it on there......crank it til the brakes are actuated then try and bleed/set the brakes then they should work......
Old Jun 26, 2003 | 03:51 AM
Are both sides giving you trouble?
Old Jun 26, 2003 | 01:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
So what's the year of this car?
Old Jun 27, 2003 | 12:49 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
its an 1984 trans am
and yes both sides are not being cool....the passenger side is leaking from where the parking brake is connected.....grr oh well i will try tomorrow to do what the autozone guy said....
Old Jun 27, 2003 | 03:38 AM
Jproz1167's Avatar
matt
try this .... I replaced mine today and had the same problem, mine started to squirt after starting the motor and pumping the brake pedal real fast and hard took about 15 tries and they started squirting
Old Jun 29, 2003 | 12:24 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
hmmm.......i never had the car on while doing it.....umm well i WOULD try that but one of my calipers is leaking out of the parking brake mount so i will have to take it back to autozone and get another one.....
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
