Spohn Lca Relocation Bracket Need Advise
Old Jun 29, 2003 | 08:13 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I finally decided to go with Spohn subframe connector for my iroc.But what i was wondering is right now i can only afford the subframe connectors and thhe shop thats gonna weld them on.Can I put on the Spohn LCA relocation brackets later on when i have more money or do i have to put them on all at once....
Old Jun 29, 2003 | 08:29 PM
MdFormula350's Avatar
you can put them on later. the reason you hear that is alot of people like to get them welded at the same time when they are getting the sfc's done, since alot of people might not have a welder and only want to pay once to get everything done.
Old Jun 29, 2003 | 09:06 PM
CaysE's Avatar
correct
Old Jun 29, 2003 | 10:04 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If you haven't installed lowering springs yet you probably don't need LCA relocation brackets yet. If you are experiencing bad wheel hop on hard accelleration however, this is really hard on the driveline. Just be easy with the right foot until you can afford to get them and have them installed.
Lon
Old Jun 29, 2003 | 10:42 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
SO do you have to Reweld the end or is it that you have to weld the LCA on top of whats already been welded?
Old Jun 29, 2003 | 11:19 PM
you bolt the top of the bracket to where the lca's use to mount on the rear end and then you weld the top and sides to the rear end. and then use the holes in the new brackets to mount the lca's back on.
6speedIROC
16
Mar 15, 2023 08:33 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Jorlain
Oct 8, 2015 01:57 AM
luvofjah
Sep 10, 2015 10:41 AM
