Stripped a lug bolt, how do i fix???
Old Jun 27, 2003 | 11:23 PM
skahide's Avatar
I pulled my rims off my 88 camaro and had to run so asked big bro to put rims back on. so i come back, all on but one. he had started putting it on with a impact gun and wasnt lined up right. so it stripped the bolt and nut. how do i go about fixing this? im driving with only the 4 right now and dont feel safe. let me know ASAP please.
Old Jun 28, 2003 | 02:23 AM
machinist's Avatar
You have no choice but to replace the stud. Hopefully you have a disk front/drum rear car and the broken stud is in the rear. If it is, you pul lthe brake drum off, take a hammer and punch and drive the stud out. Then take a new stud that you can get at most any parts store, start it from behind, and slowly pull it in with a new lug nut until it's completely seated.
If it's a front stud, you will have to pull the caliper, and then the brake rotor off and repeat the same procedure. Drive the stud out, and pull a new one in with a new lug nut.
Old Jun 28, 2003 | 08:20 AM
ede's Avatar
ede
use a press to install the studs, or take it somewhere to be pressed. you stand a good chance of damaging the stud and/or nut and it may not be something you can see with the naked eye.
Old Jun 28, 2003 | 06:16 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
whack the stud with a 3lb hammer, it should pop right out, and pick up a wheel stud installation tool at sears for about 30 bucks its about a 20 minute job
Old Jun 28, 2003 | 11:08 PM
skahide's Avatar
thanks guys. i heard that you can have Sears do it for $25. ill see then ill know if i need to do it.
Old Jun 30, 2003 | 08:09 AM
82camaro's Avatar
Car: 82 camaro SC
What he said, no press needed. Or just have someone do it for you.
Old Jun 30, 2003 | 02:09 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Thats wierd...I just shaved one of mine while driving a few weeks ago. One was shaved at the level of the hub. The other four were stripped a little from the torque.
I tried to hammer them but could not get them loose.
Took my rotor to pep-boys. They pushed out the old ones with a pneumatic hammer and pushed new ones in for a grand total of $25.
Also...when you get your new stud bolt in and fit your wheel over it, you'll notice that you have to tighten down on it longer than the other 4 to get it seated properly.
Old Jun 30, 2003 | 02:58 PM
machinist's Avatar
I just did the ones in the rear of my car and a good whack with a 3 pound ball peen popped them right out. And even though I have 2 presses here, it was much easier to use a lug nut to put the new longer studs in than it was to mess with setting up one of my presses to do it.
evilstuie
Jan 9, 2020 08:29 PM
deracer
Apr 11, 2016 12:04 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
1nastygta
Aug 8, 2015 07:38 PM
Amillionoh7
Aug 7, 2015 01:24 PM
