Need Help Installing Spohn Torque Arm With Moser Ford 9"
Old Jul 9, 2003 | 09:35 PM
killer305's Avatar
Im almost donw with installing my new rear suspension and rear end when i ran into a slight problem. the torque arm seems to be extremely close to the side os the tunnel and it hits the bolt that holds the fuel lines on. i am going to try to tighten the panhard bar and see if that helps i just want the rearend to sit as straight as possible.
Old Jul 10, 2003 | 12:04 AM
MdFormula350's Avatar
i pulled that bolt and now i am running a zip tie holding the lines in that area, that was the only very minor problem when i installed my spohn ta.
Old Jul 10, 2003 | 12:28 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Did you specify you have a 9" rear? The 9" rear mount has 2 sets of holes so you can mount the TA more inboard. My Spohn/Moser setup comes close to hitting the bolt holes you mentioned but they don't touch.
Old Dec 11, 2003 | 10:37 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Hey Killer305
I have some questions about that Moser Ford 9"
If you could please email me at tzfbird@yahoo.com
Thank you
Old Dec 12, 2003 | 03:26 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Mine clears fine...BUT again as stated above I specified moser 9" ford when I bought the torque arm...it had the extra set of holes that mounted the arm inboard from the standard location...
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
