Posi,disc 10 bolt value???
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Well it depends on what year. Well guessing it is out of you 89 Formula it would be worth more than a rear disk brake set up from a 82 to 88, cuz If it is a 89 to 92 they have 12 inch rotors instead of the 10.5 inch rotors.
Kevin
Kevin
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
It's the '89 rear with the PBR brakes right? I'd say $300-400 unles you have some bad *** interenals installed in it. It does have the 3.55 gears though, so who knows. What's it worth to you? I'd just keep it. If you're looking for $500, I doubt you'll get it. Then again, there's always Ebay...
Ed
Ed
Here's a good list for price comparison, courtesy of T/A Creations, Hialeah, FL.
http://www.tacreationsusa.com/rear_differentials.htm
Ed
Ed
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
ok, maybe you guys can answer my question. i have a 3.73 OPEN disc brake rearend. was this a factory option or did someone do a swap?
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
