Quick ratio steering box , how many turns is stock etc...
Old Jul 18, 2003 | 07:46 PM
MartinCadek's Avatar
just wondering how many turns is a stock (normal) steering box supposed to do ? (as in 2 to the left , 2 to the right or whatever the number is).
I've had to replace my box several years ago and I went with a autozone unit , then I believe I bought the "better" option they offered me (I also didn't know a thing about this stuff back then so I just opted for the more expensive piece that I figured was somehow better). Well it lets me turn the steering wheel 1.25 turns each way so how does that compare to the quick ratio steering box that some 3rdgens came with ?
Old Jul 19, 2003 | 02:53 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
You have the quick ratio, its 2.5 turns total
Old Jul 19, 2003 | 03:07 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you CANNOT measure it that way.
it changes depending on where you set the stops at.
for example, if the factory had a wider wheel, they would limit the tire from turning enough that it rubbed..
the ratio wouldnt change
but the stops would.
Old Jul 19, 2003 | 08:06 PM
ok that makes sense , but somehow I doubt a reman unit would be limited that way, would it ?
it really doesn't matter , but it is nice to go from lock to lock in 2.5 turns (with some rubbing from my SS rims :-/ )
Old Jul 20, 2003 | 01:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
all steering boxes are limited that way... how much yours is set to though, we have no way of really knowing.
Jorlain
Aug 24, 2022 05:11 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
marcusaw
Aug 10, 2015 08:13 AM
mustangman65_79
Aug 9, 2015 03:00 AM
