36mm sway bar??? energy suspension bushing?
Old Aug 6, 2003 | 03:57 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
When you measure the front sway bar do you do it in the middle? When I do this I get 36mm. If I put the caliper near where the bushings go I get just about 34.5 because the bar is a bit more oval because of the bend in that area.
When I checked energy suspensions web page they did not list a 36mm bushing the largest I believe was 35mm.
Those that have 36mm is it a 36mm bushing and where can I get a red poly unit from.
Old Aug 6, 2003 | 05:08 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Guldstrand Motorsports stocks true 36mm in red (polyurethane) or black (poly-graphite). I modify them to be externally greasable and sell them through my web site.
Lon Salgren
Top-Down Solutions
Old Aug 6, 2003 | 07:28 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Lon Salgren
Top-Down Solutions
Lon on your site the only ones I found were 205170 and they said for 82 fbody. What is the part # for red and for a 90?
Also when will the red steering braces be available?
Old Aug 6, 2003 | 07:55 PM
lonsal's Avatar
All fixed. I hadn't realized my last online order zeroed out the inventory. When inventory goes to zero it is automatically dropped from my web site.
I just picked up gloss black today and dropped off balance of the braces to be powder-coated gloss red. They always quote 1 week lead-time, but they should have it sooner than that.
Lon
Old Aug 6, 2003 | 10:47 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
FWIW Lon is a great guy to do business with. If I ever get some more spare cash it'll be going his way.
Old Aug 7, 2003 | 07:16 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I second that...Lon's stuff is top-notch.
Ed
Old Aug 7, 2003 | 12:31 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yep.
JamesC
Old Aug 15, 2003 | 03:25 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
Lon,
I would like to order the Wonder Bar (red powder coat) and the modified Guldstrand external greasable front sway bar polygraphite bushing kit.
I have a 1991 RS 305 TBI and as the original post mentioned the diameter of the front sway bar varies depending on where you measure it. The RPO code is F41 for my RS.
Can anyone confirm that a 1991 RS (RPO F41) has a 34mm front sway bar?
If 34mm, Lon do you sell the above mentioned front sway bar bushing kit for this size sway bar?
Matt
Old Aug 15, 2003 | 05:34 AM
ebmiller88's Avatar
Yes, that's right.
Ed
Old Aug 15, 2003 | 11:42 AM
bigals87z28's Avatar
Car: Check The Sig
not to knock Lon, but i got my 36 greesable bushings from Spohn. Quick delivery and i like them alot!!! anyone tell me where i can get poly greese in a tube so i can use a greese gun?
Old Aug 15, 2003 | 12:47 PM
ebmiller88's Avatar
Yup...Spohn.
Ed
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
J-money
Jan 4, 2019 09:45 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
J0386
Oct 12, 2015 07:46 AM
mfp189
Sep 27, 2015 09:25 AM
