Drag suspention
Old Aug 9, 2003 | 01:23 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Drag suspention
I am in the process of reaserching parts for a drag car and I wanted everyone's opinion or our rear suspension setup. (all parts are from spohn)
moser 12 bolt rear 4.11 gear no sway bar.
Adjustable torque arm
Adjustable LCA's
LCA relocation brackets
12way adjustable shocks
stock springs
26x10 slick
t350/400 w/ brake (possibly)
I am hoping this can hook with 500lbs torque. What do you all think?
Old Aug 9, 2003 | 05:47 AM
ede's Avatar
ede
i'd consider air bags and don't forget the front of the car
Old Aug 9, 2003 | 09:24 AM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
id also recommend air bags. you might consider the eibach drag launch springs too. you should keep your rear sway bar. it will help prevent body roll. remove the front sway bar if you havent already. id go with some bigger wheels in the back...probably 15x10.
Old Aug 9, 2003 | 01:58 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Bags are a good idea I htink we will use 'em. What all do i need to do to the front of the car? Will drag struts be enough?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
JSDaddy189
Sep 26, 2015 03:50 PM
aharvel50
Sep 21, 2015 07:31 PM
