Removing coil spring isolators - what is the consensus?
Old Aug 11, 2003 | 12:48 AM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I'm thinking about removing my coil spring isolators, depending on what my car looks like with my new wheels... I figure on the front there won't be any difference at all, but on the back there might be a noticeable difference.....
So is it a bad idea/thing to do, or it doesn't matter? If I do, I'll probably slip garden hose or cut up a bicylce tire tube up and slip that around it....
What do you guys think?
Old Aug 11, 2003 | 06:57 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
Are you talking about the stock isolators? If so, you only got them up front and taking them off would not be a good Idea. Have you seen how thin these thing are ? I know for a fact my car does not have any in the rear. But if you do it would not make much of a difference.. I do know of after maket spring isolators that are about 2 inches thick,, maybe you have these on... ????????????????/
Old Aug 11, 2003 | 09:22 AM
MdFormula350's Avatar
yeah when i changed springs, the front isolators were thin but seemed to have plenty of life still left, the rear ones seem bigger and more beefier for some reason and are still the stock ones.
Old Aug 11, 2003 | 12:01 PM
89ProchargedROC's Avatar
4th gen guys take them out all the time (rear) for lowering purposes. Especially those who run 9" rears cuz it raises the car up some. Just take them out and use some 5/8" heater hose around the top coil and put the springs back
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
db057
Aug 22, 2015 08:17 PM
TA8487
Aug 11, 2015 09:02 PM
3rdgenparts
Aug 8, 2015 07:09 PM
