How to Backspace
Old Aug 19, 2003 | 07:17 AM
CamaroDoug's Avatar
How to Backspace
I am trying to figure out if you can create backspacing yourself or if it is already set when you buy a rim. I have found plenty of articles on how to determine what back spacing you need, but have not found how backspacing is done.
I have a 91rs with 16inch iroc rims with 245/50/ r16 tires that when i turn somewhat sharp will rub against the inner fender.
They rub in the back of the wheel well towards the compartment of the car. If my car is parked I can turn the wheel and see where it barely touches, but when i drive it actually touches more. Do you think my suspension is sagging too much or do you think my backspacing isn't correct?
Old Aug 19, 2003 | 11:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, backspacing is already set when you buy a rim. Unless you wanted to un-weld the center from the outer edge, and re-weld the center into the correct position.
Just don't turn the wheel as much... seriously!
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
