got pictures of prop valves?
Old Aug 19, 2003 | 03:16 PM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
I'm pissed... I put my disc rear in almost two weeks ago, I've been driving without the right prop valve in since then... I asked the guy who I bought the rear from if he had the prop valve, he said yes, and sent it to me.. I get it, and I go to put it in, and it's the wrong size threads.. he said it came from a 1990 car.. mine's a 1991.. should be the same thing right? do the valves look different from the pre-88's and 88+? I'm wondering if it was from an 87 or something.. here's some pictures of what I have.
Old Aug 19, 2003 | 03:17 PM
Car: 91 Firebird
Transmission: A4
and here's the one he sent me... can anyone verify from the pictures what style (year range) the valve came from?
Old Aug 19, 2003 | 03:58 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
From the looks of it, it's the same as the one in my 83 T/A.
And yes, the theads did change somewhere around 85-86,IIRC!
Old Aug 19, 2003 | 09:23 PM
Car: 91 Firebird
Transmission: A4
I believe they changed the brakes in 88.. which would mean this prop valve is from a pre-88 car.. it doesn't make sense though, cause the guy says it's from a 1990.. even if the rear is from pre-88, the prop valve would probably still be 88+ unless he wanted to change all the steel lines and fittings... hell if I know... so now who wants to sell me a 88+ disc brake prop valve for cheap?
Old Aug 19, 2003 | 11:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's definately a prop valve from pre-85.
If it's an 82-83 prop valve, it'll have standard threads instead of metric threads.
(All '84 up prop valves and -all- brake equipment used metric ISO "bubble" flare fittings for -all- GM cars.)
Old Aug 19, 2003 | 11:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey you know a brand new one is only $90 from GM, right?
Old Aug 23, 2003 | 03:23 PM
Car: 91 Firebird
Transmission: A4
actually, GMpartsdirect.com has them for $50 (plus S&H, which should be $7.95 on something that small) ...
Old Aug 23, 2003 | 11:38 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Yep i got mine from gm partsdirect for 58.26 w/shipping.The prop valve you received is the early cast iron type.GM switch to the alum one in 86 or so.Also gm change thread pitch.In 89-92 the pitch is steeper than 84 1/2 to 88,but only on the 2 top fittings for m/c to prop valve lines.Plus the early 82-84 use different flaring on lines.heres a pic from andys z28 cd
Old Aug 23, 2003 | 11:50 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
hey im doing the same swap...i got a '88 GTA rear in a 86 T/A...will the 88 prop valve fit the 86 fittings?
Old Aug 23, 2003 | 11:57 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
They should be the same according to the info in the pic.When i switch to 1le brakes using the valve in pic over my stock 84 Rr disc vavle.It bolted staight in,brakes fitting & all.Only had to slightly bend 1 or 2 brake lines to line up to prop valve fittings.
deracer
Apr 11, 2016 12:04 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
chubsworth
Aug 26, 2015 02:34 AM
NBrehm
Aug 25, 2015 11:49 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
