12 inch Vette brakes on 3 gen.
Car: `89 Firebird Formula LS1
Engine: LS1 HA HA HA
Transmission: 4L60
Hello
Were there any thirdgens with 12 inch front disc brakes?
The reason why I`m asking this question is that I have possibility of buying 12 inch front disc brakes with calipers from a `93 Vette very cheap. But after removing the wheel I found out that they won`t fit because of different brake mounting
I wonder if there were any 3gens with 12" front brakes.
Regards
Marcin
I wonder if there were any 3gens with 12" front brakes.Regards
Marcin
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i swear i read something not very long ago about using vette brakes on thirdgens, someone on here was selling modified spindles for the swap.
Transmission: 4L60
Thanks for help!
But in the thread you`ve linked there are rear vette rotors, which are smaller and I`m trying to put the front rotors. Guess that`a impossible at all
Anyway thanks for reply.
Marcin
Marcin
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... send ebmiller an email.
Basically you create a hub from a rotor assembly, build an adapter bracket and bolt everything on. There is also a C5 version.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
