Not using emergency brakes??
Old Sep 4, 2003 | 09:38 PM
pontiacZ28's Avatar
Is there any problem with not using the e-brake on the disc brake rear?
Old Sep 4, 2003 | 10:21 PM
onebinky's Avatar
If you have an auto it doesn't matter, if you have a stick I highly recommend using it. Also, if you have an auto and you don't know if the parking brake has been used, DONT pull it unless you're prepared to replace your cable. They are notorious for rusting up and freezing in the engaged position
Matt
Old Sep 4, 2003 | 10:30 PM
pontiacZ28's Avatar
The car is a stick but i heard that with thte 2nd gens you had to use the e brake or the brake wouldn't function right. but it may have been b.s.
Old Sep 4, 2003 | 11:07 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
The parking brake must be used on these and most other vehicles that have the parking brake mechanism built into the calipers. This is necessary to compensate for pad wear. If you don't, the caliper pistons won't adjust and it will cause increased pedal travel. If you're afraid to use the parking brake for fear of the cables sticking, you can manually actuate the parking brake lever directly at the calipers.
Old Sep 5, 2003 | 06:48 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Lack of use means a non-working parking brake. So use it with both a Auto & Manual.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
