Lowering and 60ft times
Old Sep 6, 2003 | 02:21 PM
erummel's Avatar
Car: 92 Z28
Engine: aint got no engine right now
Transmission: need one of those
I need to a little help in settling a friendly disagreement between two people. My brother made the statement to me that lowering a vehicle (i.e. just doing the springs and nothing else) will aid in reducing 60 foot times on the drag strip.
My response to him was to say that is total BS. I asked him to prove this to me and needless to say he has not done been able to do so. Because of that I agreed to post this question and see what is really what.
Thanks in advance for all replies.
eric
Old Sep 6, 2003 | 03:25 PM
MdFormula350's Avatar
lowering springs will cause the angle of the lower control arms to change alittle bit, not in a good way most of the time; thus thats why spohn and other companies make lower control arm relocation brackets.
lower springs would be good for autocrosisng and handling, but my eibach drag springs lifted my rear end some and they are suppose to improve 60 foot times.
Old Sep 6, 2003 | 04:25 PM
Buck268's Avatar
Lowering the vehical will actually HURT 60' times, as it will cause more wheel hop due to the new angles of the LCA's, as MdFormula350 mentioned.
Old Sep 7, 2003 | 09:24 AM
Pontiaddict's Avatar
Not to mention a lower CG will hurt weight transfer to the rear wheels.
Old Sep 7, 2003 | 09:30 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
well i can tell when i did lowering springs i did lca relocation brackets and spohn LCA's and panhard rod.. and with that setup it definitly handles alot better, and aleast of the street is feels a bit better then stock off the line... i think alot of it is personal preferance
Old Sep 7, 2003 | 01:52 PM
FLYNLOW92rs's Avatar
Just throwing some springs on, as Mdformula mentioned....
Now if you lowered the vehicle properly and did everything right, then you will see a difference...
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Street Lethal
Aug 14, 2015 08:25 PM
