Direct bolt on aluminum brake caliper upgrade
Old Sep 7, 2003 | 09:48 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
I want to upgrade the front disk brakes on my 91 Camaro RS and found this Direct bolt on two piston aluminum caliper from www.ssbrakes.com for $395. Has anyone installed these calipers? Seems like it would be a simple way to improve braking on a daily driver.
Attached Thumbnails Direct bolt on aluminum brake caliper upgrade-ssbrakes.jpg
Old Sep 8, 2003 | 05:31 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Those have been mentioned before, but what that upgrade doesn't do is increase the size of the rotor which is what is really needed. All this does is give you a set of dual piston calipers. IMO not really worth it to just do that...a properly working set of stock calipers and upgraded pads and rotors would do better.
For that price ($400), why not look into the C4, LS1, or C5 brake upgrades? These will give you both dual piston calipers and either 12" or 13" rotors and hubs which will eliminate having to mess with bearings every time you want to change rotors.
Ed
Old Sep 8, 2003 | 05:46 AM
Dr G's Avatar
There was an in depth discussion regarding this a while ago. See this link:-
New SSBC Calipers
https://www.thirdgen.org/techbb2/sho...on+replacement
Though as Ed says, better value may be found elsewhere - with better braking ability also.
Hope that helps!
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
