need help with SFC's.this is urgent!
Car: "My American Dream"
Engine: V8
Transmission: auto
Help! am going to have subframe connectors made by a local shop.
I know whta they look like and where to install them but i need technical drawings so that i can give them to the shop and they can make them. NO i am not going to buy them because i live in europe and it is total waste of money to pay for the shipping which would almost double the price.
pretty much any dumbass can figure out how to make SFCs if he can work steel. all you need is a car to fit the parts to. employment with NASA isn't required. as for what they look like take a look at some sites of the differant makers, mix and match design features that you like and want.
Ya i've made some for cars and its pretty simple. I always use 2x2x.25 metal too. Most makers/manufactuers only use like .125 thick metal but i figure its basicly part of your "frame" so why worry about weight, just the strength. Mine are so strong that the car will sit even up front w/ only one jack stand under the drivers/passenger side. SFC's are absolutely amazing!!!!!
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I have a set of jegster SFC's that are copied exactly, the only thing is I don't have were it mounts to the car. How did you bolt/weld your's to the car? I know the front was the floor boards with these jegsters and the back where through the LCA holes. Is there a better place to do it? Thanks. I need to get these in before I crack a t top.
Jason
Jason
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
luvofjah
Sep 26, 2015 08:28 PM
