did a search, changing rear PBR brake pads?
Old Sep 18, 2003 | 02:10 AM
89ProchargedROC's Avatar
well it seems simple enough but i know im missing SOMETHING. I cant quite make out what chilton's wants me to do and i would like to make sure my brakes works correctly
anyone have an answer, step by step, kinda thing?
so far i unbolted the caliper from the bracket and took the pads out. Thats it
thanks
Old Sep 18, 2003 | 01:45 PM
MdFormula350's Avatar
u just need to press the piston back into the caliper to make enough room for the new pads to fit over the rotor. thats all i would do then bolt everything back up, thats at least the way i did it for the fronts.
Old Sep 18, 2003 | 03:05 PM
the rear is different due to the emergency brake
So have you actually changed rear PBR brake pads, yes/no?
Not to be a dick but if you haven't i need to know that because this has to be done right and the rears are different from the front.
If you haven't, thats cool i do appreciate the help. Hopefully someone can post here that has and we'll both learn
Old Sep 18, 2003 | 03:06 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
What he said was right, just use a C clamp and press the piston back in there.
Old Sep 18, 2003 | 04:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right, the PBR rears are almost exactly like fronts, as far as changing the pads. Not at all like the cast-iron Saginaw calipers where you have to monkey with the parking brake to screw the piston back together.
Make sure the caliper carrier slides freely on its pins.
Old Sep 19, 2003 | 01:23 PM
Thanks a lot gentlemen....i appreciate the help
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
