So what is the V12 phoenix injector really like?
Old Sep 21, 2003 | 05:13 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
I am just about to bleed out my whole new brake system. I have heard a lot about the V12 injector from some of you guys in the States. Is it worth me shipping it to the UK?
Does the m/c have to be bench bled if you use it?
Any help is appreciated.
Andy.
Old Sep 22, 2003 | 12:35 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You already know my answer... it's awesome!! I wish I bought it years ago. Even had fun when I replaced my dad's blown out brake hoses (reminding everyone again: if you haven't replaced those hoses yet, do it today!)...
1. used hose-crimpers to pinch old hose in the middle
2. Disconnected caliper
3. attached new hose to caliper
4. reverse-bled caliper with phoenix injector- injected fluid thru bleeder, with hose pointing upward- no air in caliper or hose
5. Removed old hose from steel car line
6. attached new hose to steel line
7. reverse-bled caliper, forcing fluid in thru bleeder screw; air rises, so once I saw bubbles/new fluid in the reservoir, I closed the bleeder and removed the tool
Done, 10 minutes, no need to press a brake pedal or get brake fluid squirting anywhere.
I think I told you but http://www.toolparadise.com has the V12 for less then from http://www.brakebleeder.com . You still have to bench bleed the m/c but it's foolproof. Note that I haven't bled the m/c yet with it... one of these days I will. Brakes are great, no need to mess with anything
One day I'll pick up a mityvac just for flushing the system (sucking all dirty fluid out) and for testing vacuum, but I'll never use one to bleed brakes.
Old Sep 22, 2003 | 05:13 AM
ede's Avatar
ede
it was hard to spend the money when i got mine, but after i got it i wish i'd bought one 20 years ago. it's the best way to bleed brakes that i've seen or used.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
