brake lines..
Old Sep 23, 2003 | 09:23 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
brake lines..
i wanan redo my brake lines when i put in my line lock, wilwood prop valve and the 1LE brakes. now the fronts i know i can bend my self and stuff but what about where the rubber lines from the calipers meet the hardline, is that fitting special? the rear main line i need to replace as well, is that somethin GM has to sell me or somethin i have to custom bend?
Old Sep 24, 2003 | 05:34 AM
ede's Avatar
ede
most if not all lines from gm will be straight and you'll have to bend them anyway. soft lines can be had at any parts store. hard lines are easy to bend too, buy a quality bender and you'll have no problems. the soft line to hard line is a standard flare fitting either double or bubble flare.
Old Sep 29, 2003 | 04:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
http://www.classictube.com and others sell the front-to-rear hard line; I believe it comes pre-bent, but also bent into a huge "roll" that you need to un-wind.
Find a $30 ISO bubble-flare tool at http://www.toolparadise.com ... I wasn't able to find them locally.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
