WHERE TO ATTACH SPOHN SFCs!?!?
Old Sep 26, 2003 | 03:54 PM
1989TransAm's Avatar
My car is at the shop getting a bunch of stuff done to it, but Spohn didn't inclose instructions, or the guys lost it...i need to know where to attach the sub frame connectors, diagram would be awesome...and there are 2 extra tubes about 1 foot each in length, what does he do with those?
Old Sep 26, 2003 | 04:00 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
check out spohns website, they have pictures
Old Sep 26, 2003 | 04:52 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
First off, it always helps to call the manufacutrer when you have a problem. He does include instructions and I think you can get them from his site.
Did you do a search? Here's the pics myself and others took of our Spohn installs...let us know if you need anything else, this link should do the trick.
https://www.thirdgen.org/techbb2/sho...ht=sfc+install
BTW, those 2 small tubes are for the crossmember supports. Look closely at my pics and you'll see them.
Ed
Old Sep 26, 2003 | 05:57 PM
whew, thanx everyone, i called spohn ( i thought it was saturday and they would be closed) they gave me a link to their site for pictures, and he emailed me instructions, thanx again for all your help.
Old Oct 2, 2003 | 11:55 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I have a set of SFC's that are exact copies of jegsters. However I don't have the plates that actually mount them to the car, the set I copied, the guy put them on the car before I could finish them. I guess I will figure it out this weekend when I get the car in the air. I know under the front floor pan there was a plate that followed the curve of the floor pan and thats where they bolt in, and the rear has brackets that go next to the LCA mounting holes.
Is there a diffrence in the brackets between bolt in/weld in SFCs? I am going to weld mine in.
Thanks for any help. I need to get these in soon.
Jason
Linson
Oct 24, 2025 02:00 PM
MrPackstin
Oct 25, 2017 08:09 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
gord327
Oct 3, 2015 01:25 PM
Linson
Oct 1, 2015 09:50 PM
