problem w/ rear disc
Old Oct 2, 2003 | 06:37 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
Transmission: TH700 R4
Axle/Gears: 3.08 drum
I just got an 89 iroc recently w/ a 3.70 9 bolt rear, PBR set up, and there's new pads on the back. Went to the emissions test and found out I have no rear brakes. I can see that the new pads aren't even touching the rotors. The master cylinder has stayed topped off, and I also noticed that after driving, the master cylinder was really hot. Is this normal? I don't see any leaks anywhere. This also isn't the stock rear end that the car came with, it originally came w/ a 9 bolt PBR disc, 2.77, pretty much the same set up. So what should I look at?
Elephantismo
Feb 13, 2019 12:51 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
88rscamar0
Sep 23, 2015 09:08 PM
CatmanFS
Sep 19, 2015 09:00 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
