Which combo valve to use
Old Oct 16, 2003 | 05:21 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I'm putting the final touches on a 9 bolt rear with PBR brakes for my 90 Formula and have a question. Which combination valve do I need to use? I was planning on using the 1LE valve (btw anyone got the part #?) but I recently read a post about using the regular disc/disc valve if you don't have the 1LE brakes up front. I won't have the front brakes for some time and I may decide on another option for the front between now and then as well, but I need the right valve for what I will have after this swap. I'll have the regular disc brakes up front and the PBRs with 12" rotors out back. Which valve will do the best job?
Old Oct 16, 2003 | 06:20 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Just get a valve for a 4-wheel-disc non-1LE '90 TA. The 12" PBR rears and single-piston fronts is what they came with anyway.
That or gut your stock valve and add an adjustable one. That way you can just re-adjust it when you upgrade the fronts.
Old Oct 16, 2003 | 09:57 PM
z28cdoyle's Avatar
Car: 85 IROC
Engine: 355
Transmission: Tremec 5 speed
I would recommend you gut the stock valve and add an adjustable one. I did this a few years ago on my car and wow what a difference. I think for the first time ever, I actually had rear brakes.
Additionally, with the non stock setup and your plans to change the front brakes, the ability to adjust the rear brake bias will sure be nice.
Old Oct 17, 2003 | 06:29 AM
Mongoose's Avatar
Car: 90 Formula
I think I'd rather take the easy way on this one and just get a disc/disc valve. I went through enough trial and error setting up my suspension that I'm a little burned out right now. Got the part number for that valve?
Old Oct 17, 2003 | 10:37 PM
z28cdoyle's Avatar
Car: 85 IROC
Engine: 355
I can certainly relate to being burned out from working on the car too much. The nice thing here is that the stock proportioning valve and adjustable ones are not that expensive. You can switch to the adjustable one any time.
I can't help you with the part numbers.
Old Oct 18, 2003 | 04:42 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Here's the part number for you:
1990 Brake Combo Valve (J65) - 10136841
This number may have ben superceded by an updated part number, but a dealer should be able to confirm this for you.
drptop70ss
Oct 4, 2015 09:44 PM
Formula8r89
Sep 22, 2015 04:24 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
