stock backspacing
Old Oct 17, 2003 | 01:43 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
stock backspacing
what is the stock backspacing and offset for the 16" diamond spoke rims? are they different for front and rear like the irocs? if i were to get some wider rims, say 18x9.5", which is 1.5" wider than stock, would i add/subtract 1.5" or .75" to the offset or the backspacing?
Old Oct 18, 2003 | 04:56 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Offset and backspacing are two different things. Backspace is the distance between the mounting surface of the rim and the backside of the rim. Offset is the distance from the rim's mounting surface to the centerline.
For the factory GTA style (diamond spoke) wheels the rear backspace is 5" and for the front it's 4.25". The offset is Omm for the front and +16mm for the rear.
For more detailed info. on how to fit wider rims go here:
http://www.skulte.com/adapterfaq.html
Hope this helps.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
kah992
Aug 19, 2015 02:55 PM
