Strut Upper nut Torque?
Old Oct 16, 2003 | 06:35 PM
Jurrel's Avatar
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
Okay a Very dumb question I am sure. How do I torque the upper strut nut down to 50 lbs? I only have seen the torque ratchets no torque wrenches. And if I dont have a wrench on the upper end of the strut, the entire rod turns.
I am sure I have missed something obvious. Also, on the lower nuts, how, without air tools do you get them to torque down to 195lbs? I only weight 180, so standing on a breaker bar wouldnt help.
Thanks!
BTW This is a 1984 Firebird, v6 2.8L
Old Oct 16, 2003 | 10:10 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
1) when i did mine i didn't actualy torque them, dead on to 50lbs. same issue, you had, i guess you could say we guessed. maybe its only 48lbs, but hey.
2) get a bar that is more than 1ft long at 1.5ft you weight enought to torque to 270lb/ft
Old Oct 17, 2003 | 03:49 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You need a crowsfoot adapter and a short extension. That way you can tighten the outer nut, but still hold the center stud with another wrench.
You need to use a short extension to "lift" the torque wrench up away from the crowsfoot, otherwise you won't have enough room to work in.
From craftsman.com's site:
Old Oct 19, 2003 | 08:52 PM
laiky's Avatar
They make box wrench extensions for torque wrenches. This is used where a ratchet wouldn't fit. However it requires you to do a calculation based on the length of the extension to determine what torque indicated on the torque wrench would equal 50 at the nut. I just make sure the lock nuts are good and make them as tight as i can by hand. my tokico's have a 10mm hex above the threads. i put a socket or wrench on that and use a large wrench on the strut nut. Then i groan really loud.
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
Antips16
Oct 30, 2015 06:42 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Fox118
Sep 12, 2015 09:29 PM
