Will my valve work?
Old Oct 26, 2003 | 01:45 AM
SweetRide45's Avatar
Will my valve work?
First off, I have a '90 Firebird 3.1 mpfi. It has a disc/drum combo on it now. I plan on swapping this out w/ a 9 bolt Borg Warner Posi Disc Brake rear-end from, what I believe, is an '87 t/a. My question is, will I need a new Proportioning Valve, or can I use the stock setup? I also plan on swapping the front and back disc setup's w/ Baer Street packages...Front w/ 13", Back w/ 12".
How would my stock Braking equipment hold up to these new additions?
Thanks for the help!!
Old Oct 26, 2003 | 06:24 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Technically you will need a different prop valve but I'd test the setup with what you have and see how it works first. But make sure those '87 calipers are in good working order first. Those are the "bad" calipers, prone to freezing up and not working. Are you set on getting those brakes? If not, just go to PBRs from a '89-97 system.
Ed
1992rs/ss
Jan 31, 2025 05:10 PM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
