Bolt In Rear Coilovers
This may be old, but I just thought I would throw this out there. In the "whats new" section of the Hot Rod magazine I got yesterday there is a company that makes a bolt in coil over kit for our cars using QA1 adjustable shocks. All they provided was a phone number, no website. Maybe someone else can post the company and phone # as I'm at the library right now.
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
It may be a better choice to use, but not for our stock location. I've heard that the stock upper shock location has been known to be fairly week and it would take a lot fabricating to reinforce that area. I would also do away with the rubber bushing on the top of the shock since that lonely chunk of rubber/poly would be the only thing holding up the weight of the car. There are other ways of using an adjustable spring perch in the stock location.
Car: 1987 FIREBIRD FORMULA/ 1997 Firebird (both T-Tops) =)
Engine: 305 5.0L V8 / 3800 Series II V6
If coilovers are you only approach I would suggest what slowTA says. He is right on. It is a weak spot but also w/ coilovers...you will get lots of rattle and noise....just happens...
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
Eric-86sc
Apr 3, 2016 03:52 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
