LCA relocation brackets and rear end stress?
Old 11-17-2003, 11:25 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I noticed that these little brackets ACTUALLY ARE the best mod as far as a traction upgrade. I have all the other stuff done: SFC, LCAs, Premium Struts/shocks and Springs, Panhard Bar and TQ Arm.
The biggest difference I recently felt is after I welded on these brackets my car really hooks up! Some times to a point where I think my Centerforse clutch is slipping.
My question is: Does this put more stress on the rear end? Mine is stock w/100K+(sans the 4.10 gear change) and my engine and tranny are upgraded.
Old 11-18-2003, 01:06 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Shock loading...If you're hooking harder, it's harder on your rear end. If you're running slicks and hooking hard with a 10 bolt, you're pushing it to the limits.
edit:
60-----2.440
If this is the best 60' you're getting, you should be fine.
Old 11-18-2003, 06:26 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
That 60 foot time was before my suspention mods. I'm hoping to reduce it.
Old 11-18-2003, 08:22 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I'm cutting a 1.84 on radial tires and no SFC's, LCA's, brackets on a t top car. After these mods I hope to hit low 1.7's then buh-bye stock 7.5 bolt. Damn cheap rear ends.
Old 11-19-2003, 09:42 AM
MdFormula350's Avatar
yeah with all my suspension done i am definitely putting power to the ground but the tires still cant hold first gear at the track, i know i have alot better 60 foots in the car.
Old 11-19-2003, 11:07 AM
ATOMonkey's Avatar
As long as you're running radial street tires you should be ok.
The factory 7.5 10 bolt rear is really hit or miss. The process control on the materials and machining is so loose that sometimes one comes in right on the edge of unacceptable, while others are made really well and never break.
Old 11-19-2003, 05:58 PM
LilJayV10's Avatar
Engine: 406 Roller
I hope mine is the latter of the two
hectre13
12-11-2023 08:14 AM
sweet_87_iroc
09-25-2015 10:01 PM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
Jlanz55
08-17-2015 07:15 AM
Quick Reply: LCA relocation brackets and rear end stress?
